removing my cab
Erie pa
Michael
Scottsdale c10
okay guys i need help here doing a frame off on my 84 chevy scottsdale c10 my bolts are spinning what would be the best way to remove them just cut 4 squares inside the cab to get access to the mounts?also was wondering about new bolts and mounts was thinking grade 8 stainless bolts and energy suspension mounts anyone ever use energy suspension mounts do they last/thank you!!!
Camar068
Air Force Supporting Member
10 yrs Air Force
Not sure about removing the bolts but energy suspension bushings are great.
74 Shortbed
Yep, if the bolts are spinning you'll have to cut access holes. Energy Suspension has quality stuff..
Hoodless
Willet
Chad
k20 c10
Yup, cut holes, I had to on mine, use a hole saw so it's clean and easy to weld back up
Sent from my SAMSUNG-SM-N910A using Tapatalk
74 Shortbed
Myself I would use body plugs, if for some reason down the road you have to get to them again won't have to bore new holes..
Erie pa
Michael
Scottsdale c10
gonna have to do that never thought of a body plug thank you
Jiggity76
Iowa
Greg
V1500
5.7 V8
Yep, gotta cut holes. I recently did mine and I used a hole saw. I used a piece of flat thick steel to stop the washer from spinning so I could spin the bolt out. The two rear ones spun on me but the front ones came out nice and clean. Good luck.
Gurn
