Rear end swap questions
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
Just picked a donor vehicle ('03 Yukon XL) to start my LS swap and got to thinking about rear disc.
Has anyone heard of or know if the Yukon/Tahoe rear end will work under a square? With minimal fab...
CSFJ
Iirc, it's a couple inches wider than the squares hed. Ends up making the track width nearly the same as the front on a 4x4. Not sure if the same applies to the 2wd models. I've seen some debate as to wether that affects turning radius or not. Otherwise, it's just a matter of welding the spring perches in the correct spots, and possibly the shock mounts too.
radio2000
South Carolina
83 and 88
I think my plan is to 4-link it, was just laying around wondering about the width.
It's wider and 6-lug. Personally, I don't care for those rear discs. Yeah they work ok usually, but the hardware is fragile and everything tends to rust up on them. Also, parking brake adjustment is critical to get them to actually hold well. Really no improvement over the old drum brakes.
I understand that you will already have the axle and brakes at your disposal, but the axle width may be a big issue depending on your plans.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Rear disc is fine, you just have to change the proportioning valve in the front of the truck so that it is a 4 wheel disc setup and if you think about it the proportioning valve in the modern trucks and suv's is the ABS computer. There is one you can get for the conversion here for about 90 bucks but I can not attest to if it is 100 % correct or not: https://www.carolinaclassictrucks.com/74-96-Workhorse-Van-prop-valve-4.html
Alternatively you can put in an adjustable prop valve for the rear brakes and then set it and forget it.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Sounds like a RONCO commercial...
I was literally watching an episode of Futurama last night that had Ron Popiel voice acting in it.
FenderBanger
