Rear Driveline Help
Killer
Bend, OR
Cliff
K20 Camper Special
INFO: 5.7,TH400,NP203, FF 14 bolt. Long bed 79 truck. Need to know what year range of rear driveline will work? One piece with slip yoke. No flanges just U-joints at each end. Looking for a good used first if possible since my slip splines are shot. If you know of a new made to length affordable option I am all ears. Don't need a high HP shaft just a OEM quality one. Mine is approx 57" cap center to cap center. Measured best I could without help.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Check your local driveline shop, they can likely hook you up with a good one with new Spicers for less than you can source. They can also just do the slip and splines on your shaft and as long as it is staying the same length it should more than likely be under a c-note.
Killer
Bend, OR
Cliff
K20 Camper Special
Thanks! Sounds like I will be making a few phone calls tomorrow.
twzorek
