Rear blinkers and brake lights not working
Willson
oxford ms
sierra 1500
I have a 1981 motor tranny in 85 body
Pretty sure flashers good and bulbs
Can someone tell me where the ground or grounds for the blinkers/brake light are. Or any ideas on what to check. Thank you
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Any chance you checked the grounds at the tail light in behind the tail lense, check the brake switch, for the 5$ change out the flasher relay.
Tank6x2
Kurt
C30
Body ground too…
:welcome:
Try telling us a little about you, and your truck. This is the introduction thread. We have all kinds of threads to ask questions. More people will see your question and be able to answer it.
Willson
oxford ms
sierra 1500
Had a friend whose dad bought new gmc 1500 in 1981. His dad died in 91he got the truck. 2018 he was hit front frame bent. Less than 100 miles he was going to junk it. I got it for 450. Now about 8500 more I’m trying to stomp out the gremlins.
I am having trouble with run on after cut off and cold start! Put rebuild cab. Electric choke , 305 4bbl
Any advice will be appreciated. No Egr valve or much emissions left. Does the big metal element need to stay in air cleaner. I appreciate the post much
Willson
oxford ms
sierra 1500
It was a harness connection under the dash at steering wheel. The connection was next to ac duct work. Now the wire connector doesn’t seem to snap in place with a firm connection is there any way to rig that
twzorek
