Rear axle shafts
Logan Berube
Lima Ohio
Logan
Chevy K10
305 Small Block
I am looking for rear axle shafts for a 8.6" carrier with a 30 spline axle and can't find any available anywhere. the length needed is 31 5/16" if you could give me suggestions on where some are that would be appreciated.
Doppleganger
OH-MI: Just like it sounds
I'm guessing for the 86 K10? Think there might be a couple in PnP's in Toledo. Probably be easier to procure an entire rear axle. 3.42? 3.73?
Logan Berube
Lima Ohio
Logan
Chevy K10
305 Small Block
It has the 3.73 in it and it is a k10 I already have the carrier and ring hers installed in the housing I just need the axles
Shorty81
Baby Boomer
North West ohio
Darren
Welcome Logan. I'm about 10 miles South of you.
Nonstop
Ca
Nick
K2500
Probably a bit late, but if you still need it, check rockauto under 1988 v10 Suburban. Dana 2022609.
Curt
Loco Hills
Curt
K-30
Yukon,strange engineering,dts,offroad design,Randy’s ring and pinion................
Catbox
Peter
C20 Silverado Camper Special
Dorman is a parts house brand and work just fine as well.
I just put one into my Suburban to replace the stock one with 225,000 on it.
It was just starting to wear through the hardening.
The other axle is from the junkyard and is still holding up well.
nixon22
