Rear AC help
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
I am in need of a tube assy-condenser out for a 1990 suburban V2500
It is specific to a Burb with rear ac
Help!!
greencountry05
Muskogee,OK
Skinny
V1500
Why not just buy the one out of LMCs catalog? Also, this question hasn't received much attention because its in the wrong section. Maybe a mod can move it for you. But anywho......outside of a parts catalog you can check your local junkyards. My Suburban has rear air & I came across one at the junkyard that had most of the AC components still under the hood & in the back.
v2500burb
Jay
v2500
350ci
I purchased one from a guy here
It looked the same but was short
yevgenievich
Place
Name
Year
Model
Size
The one you got was short?
The line can free form to make up some length. I had to do that when replacing the condenser on my suburban. Line was almost 1 inch short but pulled out by hand with no problems.
v2500burb
Jay
v2500
350ci
Its 3" short in length and about 1" short on height
I assumed they would all be the same
My fault
yevgenievich
Place
Name
Year
Model
Size
did not know there could be that much of a difference. It should be able to spread to fit length wise, but would not sit on the inner fender. Do you have pictures under the hood? Just trying to understand what makes the set up under the hood on your suburban different.
imyourhuckberry
