Rattle can noise when accelerating from stop
SmallsTX
Central TX
Patrick
C35
i have a 81 k10 4x4 when i leave from a stop sign or a sop light i hear a rattle like noise until i hit about 5mph or so, it doesnt make the noise when im in neutral or park while reving up the truck.
any thoughts on what it could be?
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Does it have a hot air diverter valve on a stock exhaust manifold? Sounds kinda like marbles being munched when the spring goes soft.
SmallsTX
Central TX
Patrick
C35
ok ill have to check the ujoints tomorrow. theres nothing no rock in the hub caps, last thing that was done to it was mechanic adjusted rockers, how could it be detonation if i dont hear the noise in neutral or park while reving the motor.
Rusty Nail
Rusty
350sbc
Cuz there is no "load" on the engine because it isn't connected to the transmission in park or neutral. :Bye:
Might could get away with a timing adjustment. Begs the question "what forced the valve adjustment?"
That's likely what it is, the valve adjustment is incorrect. Lookup "predetonation".
SmallsTX
Central TX
Patrick
C35
i had piston slap that's why there was adjustment, ill try to get a video later on today and post it.
matt4426
NE Ohio
K35
You mean lifter noise. Maybe the dist. cap got bumped and advanced the timing a little too much?
paul8369
Powhatan, VA
c2500
I had a similar issue. It turns out that the oil slinger on the front driveshaft (2 piece shaft on a C2500) broke its staking and just started spinning. It rattles from low speed up. Might be worth a check.
SmallsTX
Central TX
Patrick
C35
heres a 4 second video i got of it,
SmallsTX
Central TX
Patrick
C35
Video would be great here. My thoughts immediately went to detonation.
Adjusting rockers does nothing for piston slap. I'd be looking into exactly what he did and why. That rattle sounds like pre-detonation, like it's got too much timing in it.
theres a video up now
sallyjeank10
