Radio wiring
TJ79Cheyenne
Somerset, WI
Torrance
Hey guys got a radio question for ya. I have an aftermarket radio in my 79 c20 and it was working fine until about 2 weeks ago. I redid the wiring so i could at least have a radio(red n yellow hooked together). Well im trying to rewire it so that my constant works again but if i do it so the red and yellow are hooked up seperately i have no power... Used a test light and my constant wire is getting power so that puzzled me... Anything that you guys can think of that i overlooked? Theres nothing going into the area on my fuseblock for the constant but that hasnt stopped it from working before.. any helps appreciated.
Konas new ride
Alberta
Gerald
Usually yellow on radio goes to constant power and red goes to ignition power.
TJ79Cheyenne
Somerset, WI
Torrance
Yup n thats how i had it wired before. For some reason it just decided to quit working. Now it only works when my red n yellow wires are hooked together.. i dont get why it would randomly quit one day
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
I assume the fuses are okay?
Did you check the power on both wires?
That's what I'd be thinking. You're constant power source lost power somewhere, either a fuse or came disconnected. :shrug: Maybe try the yellow wire on a different constant power source that you know works. Does other things work like the Cig lighter socket and such?
TJ79Cheyenne
Somerset, WI
Torrance
I checked both my constant wire and the red power wire and they both tested good. Dont think they'd test good if any fuses were blown... Its a mystery!
John81287
Mchenry,IL
V20
Could be the fuse in the back of the head unit itself?
TJ79Cheyenne
Somerset, WI
Torrance
That fuse is good too haha. I'm pretty confused about this one
John81287
Mchenry,IL
V20
Are you basing that on looks? Or did ya check it for continuity? I know it sounds silly but it wouldn't be the first time.
TJ79Cheyenne
Somerset, WI
Torrance
I'm basing it on looks. everything still looks good. the tips do look like they got burnt by something.
John81287
Mchenry,IL
V20
I'd replace it just for giggles and grins. I know it might sound silly but for .10 why not try it before you give yourself a bigger headache trying to find the issue.
TJ79Cheyenne
Somerset, WI
Torrance
I was reinstalling it with the red n yellow wired together n tried to turn it on n couldn't figure out why it wouldn't work. Totally blanked puttin the fuse back in. plugged that back in n she turned on like normal lol so dont think its that fuse. who knows though. worth a shot i suppose
Konas new ride
Alberta
Gerald
Do you have your directions for installation? Are you sure on your radio it is yellow for constant and red for ignition power??? This is the only thing i can see to be the cause of your problem. I'm not saying your wrong.. im just saying.. maybe ya got em backwards.. I'm trying to help.. not trying to be a jerk. If your twisting the wires on your deck to get it to work.. it sounds to me like you have a power loss on your supply wires..
TJ79Cheyenne
Somerset, WI
Torrance
haha yeah I have installed plenty of stereos before so I have a good idea of what I am doing. Like i said before the way I had it set up before is yellow to yellow. red to red. black to black. n it worked for over a year and a half. Then one day was driving home from work and it quit...
Konas new ride
Alberta
Gerald
hmmm... Try a different stereo.. sounds like you have a killer internal short...
Dons79C10
