Proper spark plug gap?
MisterB
Northwest
AJ
GMC K2500 4X4
1980 350 V8. Standard plugs, cap and rotor.
What should I set them to?
Sent from my SM-T720 using Tapatalk
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Stock head, ignition, etc I want to say .035
I’m at .060 with my current setup, but I’m pretty sure I’m remembering that correctly.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Should be listed on the emission sticker that's either on the air cleaner housing, or the top radiator mounting plate. My 87's by the radiator.
Clayton
Sent from my LM-V350 using Tapatalk
hunters628
Ellensburg Washington
Hunter
I just make sure there is actually a gap on the plug and I call it good. Lol. No noticeable performance difference in properly gapped plugs so what’s the point. That’s how I do it on all my rigs. Learned that trick from a vw engine builder of 40+ years.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
There’s absolutely a difference in plug gaps. Try running my gap on a turbocharged engine. Compression, flame front, timing, ignition strength...there are a ton of variables. I guess on a 160hp 8:1cr v8 it may be a wider window, but at least you’ll get longer plug life and more complete combustion.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I gap at .045
Dan Miller
K15SG
Indiana
Daniel
K15
Ive had alot of mine come preset at .045 . I use AC - R45TS in my stock 350 2bbl ,, seems to do fine for me
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Looking online .045 seems to be the recomended gap for your 1980 HEI motor.
Clayton
Dysco
Wisconsin
Gap certainly does make a difference. The wrong gap means you aren't burning all the fuel, and/or at the right time, which means you are giving away horsepower, torque, and spending more at the pump. It's a factor in the timing and performance of any engine.
Generally with a stock 350sbc,h and carb, .35 is reccommended. An aftermarket hei and/or injection is often 45.
MisterB
Northwest
AJ
GMC K2500 4X4
I would agree. If an engine doesn't care about the spark plug gap, it must be running really poorly in other areas.
Sent from my SM-N975U1 using Tapatalk
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I have pre gapped E3 in my tired ol dog so idk.... lol
1973c10
Don
.045 on HEI
X3
Dennis Blom
