Progression Distributor
Mlcdc1
IN
Just wondering if anyone is running their 350 with the progression distributor with the Bluetooth file capabilities. I haven’t seen any recent updates on its reliability/durability. Thoughts?
squareton
topeka ks
chris
k2500 suburban
Im running one on my sons 67 buick skylark with a 455. Once you figure it out its the best dist ever, especially if you have higher compression or ac. You can have it start on 10 degrees and it can jump to 18 or whatever you choose at idle. Then you can set it to pull timing at higher rpms so it doesnt ping. Especially works best with larger cams
Johns C10 Hubcap
