Power steering is noisy
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
My power steering is noisier than a mother-in-law...or is that possible:hmm:? So anyway it roars every time you turn it,im thinking it might be the rubber O-rings on the power streering shaft. I don't know. Thank you.
74 Shortbed
Any fluid in the reservoir??.
Iowan
Iowa
Calvin
K1500
350 crate
yes but ill have to paint the stick cause its hard to read.
74 Shortbed
If you're real low on fluid it will sound off, also make sure the belt is tight.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
I thought my pump was bad because it only squealed at full turn. Turned out it was the belt slightly loose. It doesn't have a stock belt because I removed AIR pump and there was no more adjustment to tighten the belt. Got a new slightly shorter belt that I can fully tighten and it is quiet now.
Iowan
Iowa
Calvin
K1500
350 crate
Ok. ill try that.
bvandrey
