Power steering bracket help:
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Ok, i've forgotten to take pictures or make a drawing.
Could you post/walk me thru a step-by-step for re-assembling the power steering brackets?
This is for gen 1 small block---circa 76ish to 87 ish on the lower driver's side.
i have all the parts and actually this is for a 4.3 v-6, but it's the same as an 8 but you already knew that.....
The bracketing is slightly different depending on whether there is an A/C compressor involved - but you should be able to figure it out from this stuff:
Non A/C:
Both with and without A/C:
Some pictures I once took in an effort to avoid your current situation:
And some showing one installed (non A/C):
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Next crisis:
You know the stud that screws into the head so that the P/S pump can pivot on?
Where can i find one of these?
Yes, i've misplaced mine.
Here is a pic to clarify:
detroitamerson
