Possible battery drain
cbrown5385
Mass
Corey
Suburban 1500
I recently took my running boards off they had lights and garbage wires running to them. Since taking them off my battery has been draining weirdly. Could one of those wires touching something else like the frame be causing a slow draw on the battery?
Scott91370
Burleson, Tx
Scott
Sierra1500
If it is touching the frame you should be getting sparks due to a direct short. Did you just cut the wires or did you cut and cap them? Guessing the first.
