Painting Intake
RedGeneral
PA
R10 Custom Deluxe
Okay so I have a BRAND NEW Edelbrock performer Intake that I want to paint. Primer or no primer. Will be using DupliColor engine enamel.
Thoughts?
Poppy 87
Bloomingdale GA
R10 Silverado
Others will confirm, but I would treat an aluminum prior to paint, whether it be etching or primer. Obviously follow the paint manufacturer instructions. Good luck
Sent from my XT1254 using Tapatalk
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Do you not like the look of the new aluminum? Don't know too many people paint aluminum intakes. What color is the rest of your motor? Do you have any pics of it?
RedGeneral
PA
R10 Custom Deluxe
I do like the aluminum look however I am going with a gloss black and red paint scheme. Below is what I want to duplicate.
The engine compartment will also be red with a black frame.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I painted mine with vht engine enamel I believe. I definitely used primer. Can’t remember which primer though. I’ll see if I can find it in my notes or thread.
It still looks good.
Part of the reason I did mine is aluminum eventually gets oil stained or smudged. I guess I could have clear coated it if I could find a clear engine enamel. As it is now, it wipes clean easily.
RedGeneral
PA
R10 Custom Deluxe
Nice Job and valid point on painting it. The Aluminum is always a great look but it won't stay that way especially if its a driver and not a show piece.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Paint it silver and from 5 feet away people will just assume it's bare aluminum. I don't find clear actually holds up that well. Eventually you'll start seeing corrosion through the clear. As RG said above, for a driver I'd stick with paint.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
It’s worth noting, that I changed my mind after I ordered the intake. Mine, as some makes/models of intakes are, is available in black from the factory. So there’s that option, too.
RedGeneral
PA
R10 Custom Deluxe
Ordering a different color is a good idea, i didn't think of that, so I did look on Edelbrocks website and the Aluminum is the only option available.
waterpirate
delaware
v10
5.7 tbi
I clear coated plenty of intakes back in the day, after a trip through the media cabinet. As already said the oil based clear shows wear and cracks, requires another trip to media to redo. I have no info on the water based stuff. I recently did my new motor in vht spray bombs and was very pleased. Paint work is 90% preparation, and 10% application.
RedGeneral
PA
R10 Custom Deluxe
Did you use VHT for both primer and main color?
Nice Name (Eric)
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I tried that too, but I must’ve bought the wrong aluminum color. I did the aluminum front drive brackets and intake manifold to match, but it looked super gaudy.
waterpirate
delaware
v10
5.7 tbi
I did not use any primer, GASP! I spent a lot of time cleaning, seriously a lot. Then sanded/polished the metal to smooth prior to applying paint. Preperation.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I usually use a metallic. There are some chrome-look paints that may look like that. I've never found them to look like chrome though.
RedGeneral
PA
R10 Custom Deluxe
Other than having it dipped I have not found anything on the market that has the same luster as actual chrome.
johnalen76
