Overdrive shifts early 700R4
86suburbanNJ609
South Jersey
Aaron
Suburban
When I got the the truck I noticed in overdrive when downshifting it stays in high gear until about 25mph and she'll shift herself. I started down shifting manually into drive and then putting it back into overdrive when over 50.I recently replaced the manual fuel pump on the truck and noticed that now going through the gears it wants to shift from 3rd to OD very rapidly around 35mph. My gut is telling me that it's a vacuum problem but I'm not sure. Any help would be appreciated thanks.
CSFJ
Have you checked the adjustment of the throttle valve (TV) cable?
86suburbanNJ609
South Jersey
Aaron
Suburban
How do I know if it's at the right adjustment? When I bought the truck I did notice that a few things were put back in half ass and I figured I would go through them as I go along.
86suburbanNJ609
South Jersey
Aaron
Suburban
This is what I'm looking at. The cable is loose not tight at all
74 Shortbed
First, get rid of that spring on the cable, then have someone stand on the throttle and make sure the carb is at WOT, if it is cable should be tight if not pull it tight then try it, at idle cable will be loose,
CSFJ
86suburbanNJ609
South Jersey
Aaron
Suburban
Well I got the TV cable tight it goes into passing gear fine but the transmission still shifts into OD almost right after it goes into third.
86suburbanNJ609
South Jersey
Aaron
Suburban
Now to add insult to injury I noticed a rattling noise by the transfer case or the back of transmission
You've got to get that TV cable right ASAP. If you're not 100% certain what you're doing or not mechanical, and don't take it as an insult, we don't know your mechanical ability from the man on the moon, but that is critical as in RIGHT NOW to be correct or you'll trash that transmission, so it might just be worth it to pay a trans shop to adjust that for you and make sure it's correct, and that you have the correct linkage correction on the carb conversion. I've seen it 100 times where a guy swaps to an Eddy or Holly carb and the transmission is trash in less than 500 miles.
86suburbanNJ609
South Jersey
Aaron
Suburban
I have a guy to look at it something definitely isn't right. Nothing is slamming into gear or anything like that but the overdrive is off. Ill be the first to tell you I'm in over my head with this truck but I ain't going to quit I'll figure it out.
Danstanley99
