Outside tire when giving it hard throttle chirps loudly
bobehud
St.Louis
Bob
91' with early 80's drivetrain
Suburban K3500
454 carbed
One of the reasons i picked this Burban up was the fresh build on both axles a 4 bolt Dana 60 and a 14 bolt full floating axle in the rear.When i noticed this the first time i called and asked the PO about it he informed me it had an Auborn locker in the rear...
That sound right for an issue like this..?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Outside tire as in a turn? If so then yes that's the locker kicking in. After driving it a while you'll learn to use steadier throttle in the turns, since it kicking in like that could be bad on a wet/snowy road. But once you get the hang of it you wont want to be without it! Especially on a trail!!
Yep, Likely what C4 said. Also if its fresh, it might loosen up a bit when it gets broke in good.
bobehud
St.Louis
Bob
Suburban K3500
454 carbed
thanks guys im learning build a little speed and lift in a corner got some loose sand on the the tires yesterday and punched going straight and both tires broke loose so its got something going on back there.
:rofl: One thing fun about posi or locker rear ends, you'll get pretty good at your backsteer reacton times and skills. Its fun going any which way but straight when the ass end is fishtailing if you put your foot in it going around a corner. When I have a posi or locker rear end, I have a bad habit of testing the rear end often to make sure its still working right. :High 5:
crazy4offroad
K-10
350/SM465/NP205
Mine is welded so there is no sudden jolt, it just squalls all the time in the corners.
bobehud
St.Louis
Bob
Suburban K3500
454 carbed
We had a real winter here in St.louis last year im already singing let it snow..lol
Screw Ice everything we own is 4wd.In laws think we are nuts.I hate i have to lock the hubs.Wifes Jeep reach down and click your in 4Wd. My 98 push a button on the Dash.
But almost 50 and whatever it is in bad weather i don't drive like moron..But those BFG MT's are going throw some snow
As long as the front axle is open, just drive all winter with the hubs locked. Then getting into 4hi is as simple as moving a lever.
bobehud
St.Louis
Bob
Suburban K3500
454 carbed
fronts open.fords you replace the lock outs with auto hub's
GM offered auto hubs too, but they aren't reliable. They were even offered on the D60, I have a brand new set.
bobehud
St.Louis
Bob
Suburban K3500
454 carbed
They are hard on the diff or weaken the axle ? It has premium hubs on it for the life of me i cant remember the name not warn
crazy4offroad
K-10
350/SM465/NP205
Maybe Mile Marker hubs? Only thing it does is your front axle shafts, diff and driveshaft will be spinning, but not pulling at the t-case. When mine was my winter DD many years ago I would leave the hubs locked and just kick it in 4-Hi when I needed it.
EDIT: "premium" usually means Warn Premiums.
WHEELMAN
HICKORY TAVERN SC
BILL
454 v8
A few years ago..when my 1996 chevy exspress van did that..the sun shield in the trans..broke..stripped..it has one of those defective.
4l60e transmission..i had a chevy dealer.trans guy to tear it out and tear it open and replace..all the parts that it needed..
The beast sun shield..was put in...tire broke lose in a stop go turn.and then i had only 2-4th gear..if you got a 4l60e.that is something to look at..
My vehicle.did exactly..what you said your vehicle did..
bobehud
St.Louis
Bob
Suburban K3500
454 carbed
I have an old fashioned 400 turbo
And if its a locker in the front, just keep 1 hub locked in so getting to 3 WD is just a matter of shifting the Tcase. In the event you MIGHT get stuck, then you'd have no choice but to get out and lock the other one.
I'm not thinking that would work if it were a limited slip unit. It would, but I'd be afraid of how hard the gears will hit once the limited amount of slip has been reached.
Hard
