Oil pressure gauge (electrical)
Huckleberry
Valley Bend WV
Donnie
K15
350ci
Hey ya'll. Do they make a aftermarket oil pressure gauge that plugs (electrical clip) on the OEM sending unit? SBC 350. or....is there any other location to put a mechanical gauge easier than under the distributor/firewall?. The gauge has a short...killing the battery. Have replaced the sending unit. When I replaced the distributor ( easy to get to). Thanks again
Above the oil filter there is a galley plug you can remove and go there. Depending on the year of the truck there maybe a pressure switch there already. In which case screw in a tee from the hardware store.
duncan_schawalder
