NP205 Pops out of low
Honest Bob
Easton PA
Ben
LS 4.8
I have a 32 spline figure 8 np205 mounted to a 4l80e using a nwfab 4l80e adapter, and a twin stick including new modified shift rails from jbcustom that keeps popping out of low (4x4 low and rear low, I havent tried fwd low). It is my first attempt at rebuilding an np205, I put in new bearings, seals, and shift collars. I suspect the teeth on the gears where the shift collars go on are worn out. I dont know the origin of the np205 but I suspect it had a hard life.
Opinions? Can I still get all these parts or do I need to start looking for a replacement?
Are the internal parts the same between a round pattern and a figure 8 np205?
I have a spare round pattern 91 np205 with the 4l80e adapter. I could use that tcase but I am afraid Im gonna have to have driveshaft lengths modified again.
MarineOne
Western New York
Teeth don't look horrible. Have you tried unhooking shift linkage and putting it in low manually from underneath?
Honest Bob
Easton PA
Ben
LS 4.8
i have not tried that! Thanks for the tip.
GTX63
Tennessee
Ty
I had a similar issue on a 203 and it was also the linkage. Soaked it in PB Blaster until I could free it up and then worked it back and forth everyday for a few weeks. The truck had been sitting outside for years.
NateP350
