NP203 leaking. Replace or fix?
Chris64
San Diego
I need to address the leaky elephant in the room. Luckily the only place my truck leaking (making it to the ground anyway) is the transfer case. It's an NP203 (full time 4wd/chain driven). It's leaking out of the output shaft area and the speedometer cable (which I'm guessing isn't good).
I don't really have a problem with it being FT 4wd and actually not having to get out to lock the wheels is sort of cool. I've not found anyone report the chain breaking. That said, the NP205 seems to be the more desired TC.
There happens to be an old (not as old as mine) NP203 for around $100 by my work. My thinking is I could buy that and do a rebuild on it at my pace and when done just switch them out without having to have the vehicle apart in the street (not allowed to be immobile). NP205's in my area are going for closer to $1,000. Then I'd need to figure out the shifting mechanism, assuming it bolts right up to what I still have to get lockers from my front wheels.
It seems obvious to me, but you all know way more than me. What would you guys do? I intend it to be mostly a street cruiser (maybe someday with a little more HP than now) and a little casual off-roading (in the desert).
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
I would take it apart and reseal it. The speedo adapter has a little seal in it. The output seal is most likely leaking due to a grove worn in the flange. You can replace the little speedo seal really easy. The output seal is pretty easy too. You want to get a kit that has a repair sleeve. Super easy to install the sleeve and they work.
Chris64
San Diego
What do you think about buying a second TC just because it's available and local and $100?
ali_c20
Austria
Alexander
C20, K5
i would, simply because if its an np203 i think they are all compatible iirc, except for rare rare setups in the 70s , but gm and ford ones should have the same parts and work i think so you can work on it. I know they revised the fluid recommendation, and something about the chains had a change, and the lube circuit possibly changed. a part time kit is good but make sure you use it or "properly" part time so its always gets lubricated
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
For $100 I would grab it. If you need the truck to drive every day then I would rebuilt the $100 unit and swap it out. That will be fastest.
If your truck is not a primary vehicle and you can live without it while you work on it. Rebuild the $100 unit first, then do the one in your truck. This way you get the experience before doing it on your truck's part. In the end you will have a spare ready to go.
75gmck25
Northern Virginia
Bruce
Just make sure you are buying a used NP203 configured for a squarebody GM truck and with your same transmission. All three major manufacturers used the NP203, and there are variations for spline count, left or right drop, etc.
oh i didnt think of spline counts
But cant the left/right be clocked?
Old Guy Bill
KY
Bill
They made a lot of 203s, and it seems theres always one for sale around me.
They’re usually advertised $100-400.
75gmck25
Northern Virginia
Bruce
I know just enough about 203s to be dangerous, so my point was to just be sure what you’re buying. I am not an authority.
It may be possible to reclock the NP203, but I’ve never seen anyone mention it except in the context of making a range doubler. Spline count may also be nothing to worry about, since the NP 203 adapter from your old transmission could be all you need.
Old Guy Bill
KY
Bill
Yes, to use your existing trans & adapter you definitely need to stay with the same spline count.
Nborden88
