No turn signals with running lights or headlights on
fmxr47
US
Justin
So as the title read, my turn signals do not work with the running lights on or the headlights on. I recently installed a relay harness and it all worked fine. I then installed some LED headlights with halo rings that turn Amber with the signals. So I wired them up the way the front signals were minus a ground because the headlights use the socket ground. So I turned the lights on and my halo rings were illuminated Amber telling me the signal circuit had power. I unplugged the front signals from the halo wires and grabbed my meter, there is 5v on the signal circuit when I turn the running lights on. I thought maybe the grounds from the front signals needed to be connected so I tried some jumper wires and it didn’t make a difference. I did not actually bolt them down but I used some alligator clips on clean metal and didn’t seem to notice any change. Any one have an idea of where this 5v signal is coming from? I also recently started having the wipers come on when I use my right turn signal which is annoying since I just replaced the wiper switch, but I believe the wiper issue happened about the same time as the signal issue. And I put the wiper switch in a few weeks back.
fmxr47
US
Justin
Anybody?
73c20jim
Tombstone, AZ
Grounds other than the ones you checked.
fmxr47
US
Justin
The only 3 I can think of is the two on the core support and engine other than ones I have added for stuff with the bed. I was wondering if it has anything to do with how the turn signals switch the signal up, and me unhooking the front signals. But when I plugged them into the new halo/signal they worked perfect alternating the halo/side marker signal until I tuned the lights on. Then they just stay Amber while the lights are on and no signals work unless I use the hazards.
73c20jim
Tombstone, AZ
Did you mess with the steering column wiring at all???
86 SCOTTSDALE
Oakham MA
Armand
Could it be the wires for the halo are backwards. I just had a similar issue with led side lights i installed on my flatbed that would work with flashers but not with running lights. Then i reversed the wires and they worked perfect.
fmxr47
US
Justin
There are only two wires for the halos since they utilize the headlight plug ground, one wire for Amber and one for white
fmxr47
US
Justin
Last time I was in there I only messed with installing the wiper switch, the column is in poor shape and needs replaced. All of the contacts for the horn switch are destroyed and the turn signal switch was a little crunchy, cleaned it up and greased it again and it feels better but still a little clunky to operate.
73c20jim
Tombstone, AZ
Might be the problem.
Edward Koleman
Pittsburgh
Ed
V20
Have you replaced the turn signal relay on the fuse panel with a grounded led relay module?
wingman50
Chicago
5.7L
I’m struggling with a similar issue attempting to convert tail lights and front parking/turn signals to LED’s. Don’t have a definitive answer however Reasearch I’ve done may help you.
Changed the 552 flasher to a polarity independent solid state flasher with a chassis ground and got the tail lights/signal lights working. My problem is with the fronts. The signals work only with the lights off. The front signals alternately blink with the side markers. LED’s require much less current than the original 1157 bulbs so the 5 volts you are measuring is leaking into your running lights and wipers and not your flasher is detecting a faulty bulb. You can try changing the flasher. Look at your old flasher, turn it upside down and look at the connecters, there will be an “X” next to one terminal and an “L” next to the other. The “X” is the 12 volts IN and the “L” is the load to the lights. When LED’s are installed in place of 1157 bulbs the bi-metal 552 flashers generally will not trigger from the removal of the 1157 bulbs. If you change the flasher make sure the “X” and “L” are the same as the 552 flasher. If you have the stock fuse block they should be the same.
My Reasearch also said to NEVER use ANY “Load Equalizer type Shorting Resistors” that connect to each side signal wire and go to ground, they short circuit the electrical system, drag the voltage low, create extreme amounts of heat and have set fires and melted wiring in both automobiles and motorcycles in attempts to load thermal 552 flashers.
I hope this helps you understand what could be going on with your LED conversion.
fmxr47
US
Justin
I just bought an adjustable solid state relay but it’s only 2 pin. I may get a 3 pin electronic relay and try them at. I have not tried the new 2 pin one yet.
fmxr47
US
Justin
I tried the adjustable flasher and it atleast makes the flashers work with the lights on but I still have the 5v, I didn’t actually check for 5v this time but my turn indicators on the dash are still partially illuminated with the lights on
jodygraham64
