No power
Illinois
Kevin
C2500
I just replaced my starter due to some issues that it was having, put new battery cables on too.
And I go to start it up and I have no power at all. I have check the fuses, battery connections, re-installed the old starter, and even put in a new ignition switch.
Im lost as what I should be looking into next. I have zero power, no lights or anything.
* battery is full charged too, less than a year old.
* it is a 1978 GMC C2500, with what I believe is a “94 era SBC 350 in it. The wiring is a mess
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
I would lean towards you damaged the wire or fusible link that connects to the starter lug. check for voltage at the junction block on the fire wall.
Wumbo
Illinois
Rob
+1
Get down there and lightly pull on the wires going to the larger terminal. if one stretches, you found your problem.
+1
Instructions unclear, I yanked on the wires like you said now the thing arcs all over the place and makes cool light affects.
87scotty
Central il
Andrew
V20
5.7 for now
bahaha yanked (gently pull) ahh same thing​
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Ah AG, not enough experience in "yanking" things??
crowe-t
