New from Charlotte,NC
Eric Sprouse
Charlotte,NC
R10
My 1987 Silverado has over heated the solenoid since I had the Hooker ceramic headers installed. I have to wait for it to cool down before it will start. I contacted JEGS. I got my headers there. They said the starter insulated wrap would fix it. It did not. I don't want to remove the headers but this never happened before. I can't have this dependability. What should I try next ?
animal
Lee
c10 silverado
350ish
:welcome: Lot's of folks will fab up a heat shield or switch to a newer "mini" starter from a newer truck to give more space between the headers and starter.
WFO
Texas Panhandle
I prefer a starter heat shield. The wrap might hold moisture, and cause rust.
I made one from 18ga galvanized, and never had any more problems. Aftermarket ones can be bought too.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
:welcome:
Smokey T
Custom deluxe 20
I didnt know about factory minis till FrankinChevy mentioned it and with a heatshield!!
I bought a proform mini. A LIL on the expensive side and Im having a few issues with shimming it as per instructions. Its like russian roulette with the grind 10 good starts grinddddd.
Flywheel is in good cindition and starter pinion is already taking a hit. Other than that the aftermarket mini works well with my heddman headers and restarts and I live in the southwest desert.
Next time Im looking into the favtory mini though.
Proform may have not been the way to go either. A starter off of a 96 and up 350 Vortec from a junk yard probably would have done the trick. Proform is China made stuff and doesn't always come with good fitament.
1973c10
Don
:welcome:
Pops
Brandon ms
Ken
1977 Chevrolet 454 Burb, 1976 Sierra 15 long bed
Sierra 15
Welcome!
Howdy!
One other thing to mention, the new headers might have just made it more obvious that the existing starter is failing.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
Welcome from Eastern NC! The factory mini is the way to go.
twzorek
