Need some swap opinions
duddyhock
Colorado
Dustin
292 i6
I have a 96 K1500 that looks like it has the 6 bolt intake manifold so its not the true "vortec heads" (guessing its just TBI) pickup runs and drives really well but I don't know if its the powertrain I am looking for and the trans slips that's why its a parts truck (also has title issues).
My other option is I have a torn apart LT1 it is missing injectors, throttle body, rocker arms and a few other things. I was thinking of making it Carb LT1 not have to deal with a few things such as wiring and what not. The LT1 has stiffer springs, .540 lift 281 duration and 108 LSA cam in it, Speedpro Stock bore forged pistons and rods. Also, I would need a trans.
What would you guys suggest?
oneluckypops
Sedalia, Mo.
Luke
Post a Picture of the engine in the 96, I have never seen a NON vortec 96.
As for the LT1 engine the ONLY way I would do that swap is if you spend use a carb, with the old style ignition system. I HATE THE OLD OPTI SPARK ****, especially in trucks!!!
duddyhock
Colorado
Dustin
292 i6
I will go grab a pic. The truck has 35X,*** and is on its 3rd engine I bought it for an around the town pickup not knowing about the title ****.
Ya that was also my reasoning with the LT1 was get rid of opti spark crap. There has been alot of work done to that engine and with it being aluminum heads and all that I was thinking Id probably make better power that way.
duddyhock
Colorado
Dustin
292 i6
the pictures are kind of shotty sorry phone is partly broken. I counted 6 bolts on one side instead of 4.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
That is indeed a TBI engine, are you sure your truck is really a 96? You mentioned title issues.
duddyhock
Colorado
Dustin
292 i6
as i said it has 300k+ and on the 3rd engine. Not by me. The truck is from arkansas and was signed by another owner. Well its been title skipping so dmv wont give me a title for colorado since its signed by someone else.
Jrgunn5150
Ionia Mi
J.R.
6.slow
I understand it's on the third engine, but I can't see someone going through all the trouble of swapping the dash harness, fuel system, and engine harness to get a TBI into a Vortec truck.
FWIW, I daily drive a 95 GMC Sierra, that has the same interior as a Vortec truck, but a 350 TBI, because Chevy never bothered to update the TBI to OBD2, they just rolled out the Vortec.
duddyhock
Colorado
Dustin
292 i6
duddyhock
Colorado
Dustin
292 i6
ya thats the year on the pickup. maybe its an early series and got a tbi. idk people are ridiculous sometimes.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Well, year aside, or whatever, a TBI swap is about as easy as falling off a bar stool when you're drunk.
What are you wanting to put the engine into?
oneluckypops
Sedalia, Mo.
Luke
I am thinking the doors are not the original doors, I am betting the actual truck is a 95 with 96 doors on it. Not that it matters but compare the VIN from the door to the dash.
IMHO I would not even consider doing the work on swapping the TBI engine over, may as well get a good Carb and be happy.
Your LT1 motor will make damn good power, If you know a confident machine shop that can modify the Intake for a old style Distributor then I wouldn't hesitate at all dropping the LT1 in it.
duddyhock
Colorado
Dustin
292 i6
I am not going to swap the tbi. Only reason i was considering it was if it was vortec heads.
The swap is in my 78 c10 with a i6.
Even though there is only 1 option without getting manifolds machined I believe I am going to go with this carb intake for the sake of availability and ease: http://m.summitracing.com/parts/nal-24502592 .
Jrgunn5150
Ionia Mi
J.R.
6.slow
Agreed, scrap that thing and go with the LT1.
bvandrey
