need help idenifying transmission
loominghawk
hampton
daniel
i have a 1989 chevy blazer 1500 with a 350 5.7L v8. my transmission has a square pan with 16 bolts. on the driver side it has the shift linkage and a 4 pin power line. and it has the number 7 stamped into it. on the passenger side it has the speedometer cable 2 coolant lines the dipstick and a hard tube that looks to connect to the top of the motor to a piston that gets compacted when the throttle is pressed. it also has a number 7 stamped into the side. the bell housing has a lower half that is bolt on. :sorry: i don't have a camera to take pictures of it. i am betting that its not a 350 trans and that its probably not a regular 700r4 it might be a 700r4e but i don't know enough to know the difference.
Swims350
Logan WV
none
700r4 being square pan and being 89 it's a 700r4.
anything newer and they turned into the 4l60 and 4l60e
loominghawk
hampton
daniel
found vin number on trans 3t8070h so im guessing its a 1983 700r4 in which case its not the original transmission. or am i reading the vin wrong its its actually a 1993 trans.
Yah, something don't look right there comparing to the ID chart. :think:
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
here is the pan i.d. info
Swims350
Logan WV
none
they had 700 in 83 so why would it be wrong?
I thought the 4l60 was the later version/name of the 700 and knew tons said it's the same, but thought it was like how the 4l80 took over the th400.
my bad.
Stickman
