Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
It doesn't make a peep! I have power coming tot he harness behind/below the license plate. There must be a break past that.Howdy from Ohio #2!
If you try to operate the rear window motor, can you hear it trying to go down at all? Most commonly if the window will go down but not up, it's a bad safety switch on the passenger side latch. Most people just bypass it.
But if the window has been down for that long, there's likely other issues from that as well. Maybe why the passenger latch is stuck. Penetrating oil and some minor shock loads will be your friend.
I have put my Power Probe into action on those. I tested the wires, I do have 12v from the fuse box. I put hot to the white colored wire, and ground to the blue, nothing. I replaced the red to factory config and retried hot and ground, nothing. Clearly I have a break, probably as it passes through the tailgate.No power lock is on the tailgate.
BTW, the tailgate needs a good ground to operate. The front and rear switches swap the +12 to the motor.
You've got a real tough one there reaching for the ps latch with the window down.
You might be able to get the window to operate by unplugging the taigate wiring (should be right behind the license plate part of the bumper) and running a heavy wire from the + at the battery to the tailgate side of the coonnector. It's a 3-pin connector. 1 is a hot feed (center one I think) and the 2 outside pins are for up and down.
It is really a tough reach with the window down to get to anything!
