My Truck doesn't exist
vintovka
or
vin
According to parts vendors my truck doesn't exist. I have an 84 GMC Sierra classic with a 700r4 AND has a column mounted shift indicator. Every source says this does not exist I need a diagram showing the shift indicator parts and how they go together Again this is NOT a dash mounted indicator. What Gives?
animal
Lee
c10 silverado
350ish
Sounds like your truck has had some van parts installed in it.
J Knight
Baytown TX
82 Chevy
350ci
You either have an earlier column in your truck or an aftermarker/repop indicator on your factory column.
@bucket and @J Knight are on the correct path here I think. Also 700R4 was not available in 84 so someone has swapped in a later model trans.
RThiel
Worland, WY
Robb
6.0 LQ9
I've had both a 1982 and a 1983 c10 with a factory 700r4. But I agree with the column being swapped with a van or a pre-1973.
Really? Maybe I'm dead wrong but I thought that the 700R4 didn't come about in factory setups til the early 90s. And prior to that was the TH350 for most 1/2 ton applications. Again, I could absolutely be wrong on that but that's what I had in my head. Can anyone clear that up? @HotRodPC @RetroC10Sport @89Suburban @J Knight @Mr Clean
The88
Mhmm
South Louisiana
ThatGuy
Assumptions make an ass of you and me but I thought it was in 88 that change came to the 700r4. But I have been wrong on a time or 2.... or more ehh
LOL Now i may need to hit up the google. could very well be 88 but early 80's as previously stated is really blowing my mind of what i thought was fact LOL GOOGLE HERE I COME!!
Well....that didn't take long. Obviously, I was way off and must have been thinking about the 4L60 :rolleyes: Carry on...
I found the below info at this link... http://www.hotrodders.com/articles/TH-700R4_basics.html
The Turbo-Hydramatic (TH) 700R4 automatic overdrive transmission was introduced to Chevrolet vehicles in 1981 for the 1982 model year vehicles.
It was introduced to the larger car (B-body and similar) and truck lines as the TH-2004R was introduced to the car line. The 200 was given a "universal" bellhousing bolt pattern for its ability to bolt to different engines (both the Chevy and B-O-P-C engines).
The 700 came in two bellhousing bolt patterns -- the standard "Chevy" which includes all smallblock engines from 262 to 400 cubic engines (and the later "Vortec" series engines and their derivatives), the big blocks from the truck only 366 to the 502, and the new ZZ572. This bellhousing pattern was also used for the 6.2 and 6.5 liter V-8 diesel engines, and it will also directly bolt up to the 3.3 liter 200 cubic inch, the 3.8 liter 229 inch V-6, and the 4.3 liter 262 cubic inch engines.
And then there was the smaller bellhousing bolt pattern used on the 2.5 liter (151") 4-cylinder, the 2.8 liter (173") V-6, and the 3.1 liter (189") V-6 engines.
The TH-700R4 was also offered in a 2 wheel drive version AND a 4 wheel drive version. The 2WD had a longer tailshaft and a housing including a bushing to support it along with containing a speedometer drive housing. The 4WD version had a much shorter tailshaft which was to be supported by the adapter and transfer case input shaft bearing, the 4WD speedometer was driven from within the transfer case rear output shaft housing. The only other difference I have found here is that the torque converter cover (dust cover) for the 4WD version was made of cast aluminum instead of stamped steel or molded plastic, and it used much larger bolts to attach to the transmission, as it also made provisions to attach strut rod reinforcements from a bracket that mounted under the motor mounts to the lower portion of the cast aluminum dust cover.
There were also a few changes made to the V-8 model 700 to give it the ability and dependability to be installed into the Chevrolet Camaro and Corvette -- and in certain cases the Corvette version received even more enhancements.
There were various differences in the same model -- transmissions needed to be able to be used with the different engines and the same transmission; obviously the 200 inch V-6 will have a bit of a problem driving the 700 that was designed to be bolted behind a 6.5 turbo diesel, or a big block engine.
The gearing for the 700 is:
First - 3.059
Second - 1.625
Third - 1.000
Fourth - 0.696
Reverse - 2.294
OR -- Rounded off to 3.06, 1.63, 1.00, .70, and 2.29.
Like I stated before the 700R4 was introduced in 1982, this transmission had a 27 spline input shaft, and many cumulative problems and bugs that had given the 700 a reputation that it wasn't reliable or desirable. It was revised to include many upgrades and changes that changed its reputation a little -- it was given a 30 spline input shaft, many internal redesign modifications and deemed to be a better version.
Without pictures, the 700 can be identified by the oilpan having a rectangular shape being longer front-to-rear than side-to-side and held to the transmission by 16 bolts, 3 bolts front, 3 bolts rear, 5 bolts left side, and 5 bolts right side.
The tailshaft housing is held onto the main case by 4 bolts, and from my own experience uses a square-cut o-ring seal, and not a gasket. The typical width of this transmission where it bolts to the engine is 20 inches overall. From the engine/trans mating surface to the crossmember mount bolt is 22-1/2 inches, and engine/trans surface to output shaft housing mating surface is 23-3/8 inches overall, with the tailshaft housing typically measuring 7-5/8 inch.
Transmission fluid cooler lines: on the 700R4 the bottom fitting on the right side of the transmission is the "out" line to the cooler and the top fitting is for the return line from the cooler. These fittings are 1/4-inch pipe thread, and CAN include an adapter from the factory for threaded steel lines in an SAE size.
The transmission fluid pressure readings should be in the ranges of the following numbers (psi):
Range Minimum Maximum
Park 90-110 190-230
Reverse 95-120 200-300
Neutral 90-110 190-230
Overdrive 90-110 190-230
Drive 90-110 190-230
Second 185-230 185-230
Low 185-230 185-230
The main case is made of cast aluminum and the 700 typically weighs 155 pounds.
All versions of the 700R4 transmissions can be affordably rebuilt with stronger components in nearly every area. Additionally, shift improver kits are available to provide firmer, quicker shifts -- reducing slippage, heat and clutch wear. There are also many styles of torque converters to better configure the transmission for off-road use.
In 1993, the designation of the 700R-4 changed to 4L60. A later version of this transmission, the 4L60E, is an electronically controlled variation, utilizing a reluctor ring (similar to that in an ABS application) and magnetic pickup, together called the Vehicle Speed Sensor (VSS). The transmission requires this feedback to map the shift points. In 1998 the 4L60E was redesigned to include a removable bellhousing and a shorter main case length, along with a 6-bolt tailshaft housing as opposed to the 4-bolt earlier configuration.
Novak Conversions makes many adapters for the 700R4/pre-98 4L60E, including: AMC inline 6 and V-8's to the TH-700R4.
TH-700R4 to the Dana models 18, 20, and 300 transfer cases, and the New Process (predecessor to New Venture Gear) NP-231.
Trans-Dapt and several others manufacture an engine-to-transmission adapter plate out of 1/8-inch sheet metal to adapt the "Chevy" bolt pattern of the TH-700R4/4L60/4L60E, to the B-O-P-C (Buick, Oldsmobile, Pontiac, and Cadillac) bolt pattern to expand the ability of this transmission to be installed behind nearly every GM engine manufactured in the past 50 years.
There are several adapters from Advance Adapters that allow these same swaps, and a few others. Advance Adapters also manufactures an adapter plate to mate Ford small-block engines to Chevy automatic transmissions. The kit consists of a steel adapter plate, dowel pins, torque converter spacer adapter, and mounting hardware.
There are also adapters for early Hemis and later model Chrysler engines for mounting GM automatics.
"Samsonite... you were way off."
Yeah, just keep rubbing it in :gathering:
I'll be wrong again in the future so rest assured this won't be the last time :D
The88
Mhmm
South Louisiana
ThatGuy
Don't know if that quote was dead on or not but it pops into my mind every time I am wrong... Dumb and Dumber.
Yeah don't worry no one is ever wrong :gr_grin:
animal
Lee
c10 silverado
350ish
@Old77 was already an a$$ so no harm no fowl :rofl: J/K wuv u man :wave:
FenderBanger
