my g80 stay locked
avilleg0
charlotte
alex
k5
i have a 1986 k5 blazer 4wd g80 3.08 ten bolt. After having problem with it pulling right after random turns. I have been able to repllicate the problem that im having. The truck will drive fine till i stop and let say i hold the brake and give it a little gas and the tires will spin a little but the truck will pull right and you can hear the rear tire kinda drag. Till you ether stop and back up or play with e steering wheel left to right you will hear a loud pop and everything back to normal. Kinda seems like the G80 sticking i did already drain all the nasty muddy fluid out of the back diff and brake clean the entire diff and replaced with new fluid but the problem still exist. any one have any idea
I removed the front drive shaft and the right front hub still does it
Georgeb
Wisconsin
George
K10 Burb Z71
Sounds like a brake hanging up or binding in the steering. I would check for worn parts up front.
firebane
Calgary, AB
Curtis
If your rear diff was full of muddy gross water then I'd going to assume your front isn't any better.
Also be a good time to check the inner seals to insure they aren't worn letting crap into the diff.
Also be a good time to start looking at bearings, ujoints and balljoints if nothing has been touched.
Just to be clear, the pull is coming from the rear (where the G80 Gov-Loc is located), not the front. So the rear fluid needs inspected and changed.
I had one stick on me exactly as described, the Gov-loc was overly sensitive to the slightly mis-matched rear tires. Installing tires with the same OD took care of it.
Georgeb
Wisconsin
George
K10 Burb Z71
So with that said a significant difference in tire pressure could also result in the same type of issue....
Hunt1
