motor swap
roy c
long island
roy
can i swap a 350 for a 454 in a 87 burb ? if so can i use the 350 tbi set-up?
just swap the long block pully's ect. also what is the cfm. on the 350 tbi?
Thanks roy c
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
350 tbi will be to lea on the 454 itll be starving for gas
You can reuse all the TBI stuff, but you do need the 454 throttle body and injectors. The 454 TB uses a different plug for the IAC valve, so you will need to wire that in (4 wires) or buy an adapter harness. The 454 TB also doesn't have a spot on the linkage for a TV cable/kickdown cable if you have a 700R4 or a TH350, so you will have to add it if you need one.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
The 350 tbi is 450 cfm.
the swap can be done, but you will only be able to re use the computer, harness, and distributor. You will need to re-chip the computer for the 454 , you can get that on ebay for $25.
You will need 454 specific knock sensore and module, and of course, a 454 throttle body which has 2" bores and as opposed to the 1 11/16 bores.
Also, while shopping for the 454 throttle body, you need a unit from 87 to 93. the 94-95 units used smaller injectors, with a higher volume Multiport injection style fuel pump.
What was the purpose in that?
Jims86
Patterson,Ca
5.7 TBI
Have not figured that one out...i do know that they used the same injectors a 4.3 used, but with the higher pressure, they turned out to be about 70pph, as opposed to 45pph with 13psi.
roy c
long island
roy
Thank you Sirs for your help
Chype1
