Manual swap
calwal97
Alberta
Callen
Hey. I just picked up a 1977 Chevy C20 with a 454 and an automatic trans. I'm really interested in putting a manual tranny in the truck. I was wondering if anyone knows which would be best fit and the difficulty of doing the change. Thanks!!
marks86
Latham, NY
Mark
12v Cummins
a sm465 would be almost a direct swap but a nv4500 is soooo much better but alittle more challenging to install
Lastwords
Lindsay
Mark
I have an small in my truck. 1st gear is useless and it shifts like an old dump truck. It's also 200+ lbs. I would go with the nv4500. The issue with it is it has electronic speedo so you'll have to a dress that.
SpooN
Charleston, SC
Paco
K1500
How do you reconcile the electronic speedo?
firebane
Calgary, AB
Curtis
I'm confused by this. If by "small" you mean SM465 it doesn't weigh anywhere near 200+lbs. Maybe if you have the transfer case attached.
You can get electronic to cable speedo conversions.
Lastwords
Lindsay
Mark
The sm465 is about 150+lbs. The other option is np440. It's a 4 speed but 4th is an overdrive. And it uses speedo cable.
Shak379
