Lowering a 1982 C20?
Jeffay
Silverdale, Wa
Jefferey
6.2 Diesel
I was wondering if anyone has lowered there C20. Just bought an 82, and really want to drop it something like a 4/6 or 5/7 but I am have problems finding kits. Any and all help is much appreciated.
pmayojr
NC
Perry
Im not 100% but I think you can use the c30 drop spindles and springs for the front. For the back you will have to do a flip kit. I did the flip on my 86 c10 for just over $100. which includes the air shocks so I can still haul and tow if I want. For the flip I went to tractor supply and bought the trailer leaf spring seats. for $10. you need a welder and a torch.
1981scottsdale
Edmonton
devin
Scottsdale
Do you have a write up somewhere of what you did? this sounds intresting, and down the ally of what id like to do.
pmayojr
NC
Perry
No write up. But I'll tell you on here .
I started by removing the bed. And both leaf springs. My truck has a Reese hitch so I used a floor jack under it to support the truck. I lowered the chassis down far enough to where I could put the springs under the axle. I used the bigger spring perches from tractor supply. You have to drill another hole in them to move the axle back an inch. Make sure the measurement is exact or else the truck will crab down the road. Set the newly drilled perches on the springs and lift the jack until the axle just is sitting in them. You will need another floor jack to set the pinion angle. I set mine parallel to the ground. Once its where it needs to be tack the perches in place remove the leaf springs for ease of access and weld in. I then bolted everything in and used a torch to cut the rivets out for the bump stops. You will need shock extenders. I bought the Monroe air shock kit for my truck and installed them like the instructions said. Then reinstall the bed. With the air shocks I have a little adjustment on the ride height of the rear.
Jeffay
Silverdale, Wa
Jefferey
6.2 Diesel
I know this one has been dead for a little bit, but I purchased and installed the rear flip kit. Just waiting on my drop spindles to show up. I'll post up picks once complete. Hoping for this weekend, but we know how that goes.
pmayojr
NC
Perry
were the spindles the same as the 1 ton?
Jeffay
Silverdale, Wa
Jefferey
6.2 Diesel
I got a set from Western Chassis. A little pricey at 400, but really good product.
cbrodine
NW Ohio
Collin
C25
did this get finished? Any updates?
Zone cone
Templeton
Shannon
Here's my 84
fnny6770
