Lost shifter spring
72velle
Kevin
84 C10 with a TH350, tilt column, column shift. I was swapping out my shifter and lost the spring in the column. I have one to replace it but will it cause any problems if I leave it in there? Will it eventually fall out?
TIA,
Kevin D
what spring, for the lever, that pulls it away from you or the one for indicator
72velle
Kevin
The spring for the lever.
Big Chip
Michigan
Kevin
C35
I think you're going to find you'll get more interaction here than on 67-72 trucks. I think that spring would just drop into the shift bowl but I'm not sure there's enough room to fall out. I doubt you'll have an issue if you don't have one by now.
Big Chip
Michigan
Kevin
C35
Also, make sure we get some pictures of that Chevelle!
I also believe it probably just fell into the bottom of the shift bowl and will likely just stay there and chill.
I think the only thing you have to watch for is its more apt to be able ot be bumped by your arm into something else because isnt reverse and park gated from just straight pushing up when in neutral D L2 or L1 or whatever they mark for a th350
but like, im not saying its a hit a bump bump im saying touch your dashboard admiring how pretty it is then oh **** a deere and your first reaction is then throwing your arm straight up in a panic which isnt something i hope youre finding yourself in
72velle
Kevin
I had the Chevelle for 21 years and sold it 3 years ago, bought my 84 square with the profits :)
I didn't get a response on the other website so I posted here. Thanks to everyone for your help,
Kevin
Big Chip
Michigan
Kevin
C35
Kevin
I've got a 68 that was my mom's for 30 years prior to me owning it. She had a 68 and then a 72 when I was growing up so I have a lot of fond memories of those cars.
72velle
Kevin
68s are cool, kind of a special car: new body style, factory strike etc.
It's a bit of an oddball but I like them.
I've always been a fan of the half-breed grille. It's unique in a way that I like.
Raptor style grille on a focus or hwatever that junk is. there has to be a GM equivalent somewhere with that ugly upside down front end
chubhub6969
