Lock nut for rockers so tight its breaking tools
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
So yeah..my lock nuts on my rockers were so tight i broke two drivers and bent an allen wrench trying to remove them. No locktight visible. Im thinking the last builder(local shop) just wrenched on them with all he had....is there a torque spec on them. Did i miss the meeting where we decided to go hulk on the rocker nuts or something?
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Definitely shouldn't be that tight. Tight enough to hold the adjustment, but should turn with a little resistance when it comes time to adjust the valves.
nvrenuf
Mobile, Al.
I'm surprised they are that tight, I've overtightened poly locks before and the nut split (spiral). Couldn't you just put a wrench on the hex nut and break the whole thing loose? Then you could work with the set screw.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
That was my understanding as well. Ive never given them more than a bit past snug and never had any back off. These I just removed had me second guessing myself and standing there looking like a jackass after the second driver bit broke and the head got stuck in the rocker nut. I cant believe how much force it took to get them off.
I had to sleeve an allen wrench with a hollow screwdriver shaft to keep it from bending more than it already had; and hit it with a deadblow.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
I hear ya. These are poly locks on 1.6 comp roller rockers .Im a little worried about these having been stressed so much. IM not sure if removing them with the set screw that tight would have been good unless I had new studs ready to go in also. Maybe it would have work out but i honestly dont know either way. I just assume the same force holding the nut on would be working against the stud somehow and booger it up, but again I do not know. Never ran across them this tight before,LOL
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
We had poly-locks on the race car, and usually just broke them loose with the hex. Before you break out the drill try a brass punch and blast it good with a BFH.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
They were off before I posted this. After breaking two 3/16 hex drivers and bending an allen wrench I wised up and reinforced the allen with a sleeve of sorts...after that the deadblow did the trick. Ive just never seen poly locks so unnecessarily tight and wanted to see if it was as uncommon as i thought.
I would have been mad at myself if I put them back like I normally do and later find out I wasnt giving it enough umph.
There may or may not be video footage of me cursing like a sailor about whoever had hands on it last. I lost my temper a bit when the 2nd 3/16 snapped.:banghead::throw:
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
I've always snugged the allen down, then put some more torque on the nut. Loosening them is reverse order, break the nut loose first, then back off the allen a bit.
I tried that and it didnt seem to want to move down(tighter) at all. I was afraid to try any harder than I was. I thought it may help but just didnt give me any movement at all until I had the hex loose. I wasnt sure about hurting the threads on the studs so I may have been too gingerly with it; but I think it should have moved if it was gonna...I have it a few grunts thats for sure.
Im just happy in the end they came off and that I was able to get the 3/16 bit head out of the poly lock. It took me longer to retrieve the broken bit head than it did to tear down both heads
SquareRoot
Propane torch or other means of heat on the nut for a minute or two and it will literally fall off the bone
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
I didnt have my torches with me at the shop otherwise it would probably have come to that. I dont know why i didnt at least bring the handheld propane with me considering how many rusty exhaust bolts I have to remove...just didnt expect to need it today on the heads.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
That's what I used to do also. There just isn't enough grip on the allen screw to get it tight enough, so we treated the allen like the height adjustment and the hex as the locknut.
legopnuematic
Licensed Junk Dealer
MO
Spencer
X3 on snug the lock and then nip down with the hex on the nut itself, reverse for disassembly.
Realistically even if overtightened the likelihood of damaging the threads on the stud/nut itself is quite low, unless if seriously corroded, cross threaded or the threads were damaged to begin with.
High quality hex keys really pay for themselves, Eklind, Bondhus, Wiha, Wera all make good quality keys.
Swearbody
Birmingham AL
Jeff
C1500
355 sbc
So it does seem quite possible that the previous build was done this way as there are many who like this approach. I did in fact try to reverse this procedure to remove them but had no luck since I was worried about the stud.
I was using Eklind ball end hex keys and thats what eventually got them off with some reinforcement to the shaft. The 2 3/16 hex bits were both Pittsburg though...and both ball end, so no real shocker that they snapped the head off.
I am going today to see what brands at the local HomeDesperate are lifetime warrantied and pick up a set of straight(not ball end) hex bits. Im thinking that if they had been non ball tip they would have been able to do it considering they both snapped at the thinner turned down area. Considering the fact that almost every bolt going back on the engine is ss 3/8 hex drive or smaller ill need some good bits anyway.
Thank you everybody for jumping on this thread. I cant wait to show off my work once everything is completed.
legopnuematic
MO
Spencer
Ball ends on hex keys for 3/8 square drive's don't seem to last under torque at all. My friends dad has managed to break almost every ball end square drive allen with their m12 fuel ratchet. If you can find a set of hex drive bits that use a straight bit with a set screw rather than a necked down one, this way if you break them you can pull the broken one out and cut a new piece for it from a donor hex key.
Something like this
Hard
