Lift kit swapping
Doug80
Chicago
Douglas
Can a 1980 k10 4in lift work on a k5 blazer? If so what years would it work on and would it still be 4in or would it be higher or lower?
firebane
Calgary, AB
Curtis
Pretty much everything from 73-87 is swappable and can be used on one to the other.
With a blazer I've heard there can be driveline issues with the front and rear shafts.
Also depends on what the 4" lift consists of.
Doug80
Chicago
Douglas
It's a rough country complete lift blocks rear new springs up front raised steering arm new shocks would it still be 4in on the blazer?
firebane
Calgary, AB
Curtis
Well it will be a 4" lift but how much you actually get depends on your rear springs and if the front springs have sagged at all.
Doug80
Chicago
Douglas
Ok thank you very much!
MadOgre
NA
NA
NA
NA
NA
Yep. Right on! Curtis. 4 is 4 on any ol square
cpender
