Leaking transmission
Yukonjack
Canada
Bill
3500 Sierra classic dually
1986 k3500 is leaking bad. It has finally warmed up and I rolled under to have a look. I thought letting it sit out the cold was the humane thing to do as well, it would concentrate the drip of trans fluid and help pinpoint the leak. I am still not clear on the source. Anyone point me in a general direction with these pics?
Yukonjack
Canada
Bill
Pic2
Pic2
Yukonjack
Canada
Bill
Parked for 2 months at least and the leak is not stoping if that helps in diagnosis.
firebane
Calgary, AB
Curtis
Either vac modulator or cooler lines I'd say.
Yukonjack
Canada
Bill
Thanks Fire. I plan on rolling up on some ramps to get a better look. I'll start there.
Maybe some better , not a lot of room atm.
mp1977K-5
Charles
K-5 Blazer
Leaking TH350 on my 1977 K-5 Blazer
I have a near stock 1977 K5 Blazer with a 383 engine, rebuilt TH350 trans, NP203 transfer case.
I have a near same issue. Leaks a bit if parked on a slope such as along a curb, then I haven't driven it for about three weeks left it parked passenger side along the curb and just two or three days a go it puked up maybe a cup of ATF.
Looks like it came somewhere along the passenger side of the transmission.
Normally I park in our near flat driveway, but had to park along the curb the last three weeks.
I've had the dip stick/and "O" ring replaced, replaced the trans pan gasket, replaced the aux cooler lines.
I'm at a lose and it driving me bonkers. "HELP"
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Maybe the dipstick tube? Has there been some "severe" temp changes in your area?
CSFJ
I've been chasing a leak on a 700r4 myself. Thought it was the pan gasket, but nothing I did could stop it. same kind of issue, steady drip while parked. I'll be changing the o-rings on my 2-4 servo next. I think It's the only other opening in the area where my leaks.
Mudbeast2
