leaf spring removal
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
ive got a 87 r10 with a 4+1 rear leaf springs. which one(s) could i take out and still get a fairly decent ride? i have dropped shackles and hangers installed.
swagger
old house in WV
Steve
350/SM-465/NP-205
The overload spring is the one I would take out first
big one at the bottom of the pack
Steve
Here's an idea that might make the decision for you:
If the springs are still stacked, be sure to separate them and inspect for a broken leaf. Sometimes they can be cracked and still appear good while assembled.
If you find a broken leaf, pull that one.
If a different one is cracked on the other side (and you don't plan on entering any truck shows) you can pull that. The stacks will look a little different but will be the same height and there won't be any discernable difference in suspension firmness.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
thanks ill check when i pull them apart.the main spring is broke at the eye. cant figure out why that happened.
FenderBanger
