Just started on the vent window overhaul
jkhll8
Keith
1987 R10 2WD shortbox
5.0 TBI
Finally got started. Got them both took out and disassembled. Gotta clean them up and get them painted now. It's not been real bad so far. Just time consuming.
jkhll8
Keith
5.0 TBI
Done
mpv86dually
Mark
c20 converted c30 dually
looks nice
Oldrider
NC
k2500
Looks great!
CSFJ
I've noticed that the seal kits offered for these are available in either one or two piece styles. Are the seals interchangeable? Does one work better than the other? Or do you need to stay with the style that was originally installed?
crpntr78
Missouri
I would like to know where you sourced your gaskets. I replaced mine with them being sourced from Precision and they leak air badly. Thanks
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I was very happy with the seals from Classic Parts. It's been 5 years, and still holding up to the Texas sun (co-worker now owns it, I see it everyday).
cah2873
East Texas
Chance
Does anyone know of place that these windows can be sent and rebuilt? I can not seem to get the seals in correctly.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Done
Looks good. I was looking at your pictures, I thought the rubber was supposed to spread around/outside the door frame channel, instead of inside the door frame channel, when installed. I'm getting ready to do mine also.
jkhll8
Keith
5.0 TBI
Thanks. As far as I know they go down in. I've seen people put them on the outside and it doesn't look good. IMO. If you have any questions when you get started just let me know.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Thanks, I'm sure ill be picking your brain when I get on mine. Are they a tight fit inside the channel, so as to not let rain water inside the door?
twitch1989
