Just found this site on the internet today.
geolee
illinois
george
I have a 84 c10 and put a 92 5.7 in it myself and pretty much done. Have to run a electric fuel pump cause the block isn't machined all of the way for a push rod. Then some wiring and should be on the road again. Sucks to not be able to use a mechanical pump. I'm sure someone here has ran into this. I just assumed it was machined since it has a block off plate
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Welcome, when I had my Square, It had a mechanical fuel pump now with my K1500 I miss pumping the pedal, and wing windows.
animal
Lee
c10 silverado
350ish
:welcome:
geolee
illinois
george
Thanks guys! This is a pretty cool site. Nothing better than a square
74 Shortbed
Welcome to the site..
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Welcome.
1973c10
Don
Welcome
Welcome to GMSB. You can always find an external electric fuel pump. You don't have to go with in tank fuel pumps. I'd probably go with a 5-8lb pressure pump if you're running a carb. Remember to run it as close to the tank as possible. If running dual tanks, I'd put it right in front of the switching valve so I only needed 1 pump.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Welcome to the board!
rpcraft
Robert
Jimmy
LS 6.0 364 CID
You can still pump your gas pedal. It's squirting fuel from the carb bowl, has nothing to do with what kind of pump it has.
Iowan
Iowa
Calvin
K1500
350 crate
I have fuel injection now. But thanks guess I never put to gather that it doesn't make a difference.
geolee
illinois
george
Just running one gas tank and already have a electric pump i think its 4-7 psi and regulator with a inline gauge. I just hope it all works out i was going to rebuild the factory block but found out it was cracked by the machine shop. Found this motor and the guy i got it from said it was good so we will see.... Probably going to get a new cam and gear drive soon if everything is good. If not time to take it back out lol
Iowan
Iowa
Calvin
K1500
350 crate
If you are doing a rebuild why not stroke it to a 383?
Hard
