kleedus
- Jan 25, 2012
- wyo
- Ray
- 1960 threw 91
- c10 to k30
- 350 threw 454
I don't know what kind of welder you have but do not use flux core wire for body work.
I use .023 wire when I weld sheet metal it is the thinnest wire you can get and it generates less heat when welding.
brace cross brace and then brace some more before cutting anything.
take your time fit everything the best you can before welding. you can use small self tapping screws to hold parts together for test fitting and welding.
and you might want to get some weld threw primer to help prevent rust in the future. paint the insides of where you are going to weld. that way the bare metal is covered on the inside where you can't paint after the repairs.
good luck
good luck
