Intake Manifold bolt length question
Maknwine
Virginia
Tom
c30
Ordered some intake manifold bolts and would like to know If I should be concerned that the new ARP bolts are shorter than the originals. New ones are smaller heads and IMO would need to have the washers which shortens them that much more vs originals.
Is this normal or should I just go buy grade bolts from the hardware store that match better? (I posted this in my BPE thread probably better to post separately)
thanks in advance.
thanks in advance.
Should be fine. The longer bolt length is usually to account for the big thick metal brackets that are used for lifting hooks. If you aren't putting those on, you will definitely be fine. You only torque the intake manifold to something like 30ft-lbs, so it doesn't need a whole lot of thread engagement. Make sure you put some thread sealant on the bolts though so that oil doesn't make it's way up the bolts and onto the top of the intake manifold.
Hard
