Instrument Cluster
cah2873
East Texas
Chance
Hello,
I am new to the forum. My son and I are working on a 1984 Chevrolet K20 for his 1st ride that we got at a cheap price. You will see me on here asking several elementary questions about these trucks. The instrument cluster is hard to see so I removed it this afternoon. It looks as if I need to purchase a new clear lens to go over the gauges because it looks as if someone sprayed a cleaner on it and it smeared the lens. I also need a oil pressure and a temp gauge because they do not appear to be working. I was looking at some threads where LED lights have been installed into them also. My question is where is the best place to purchase an oil gauge, temp gauge, clear lens overlay and also a new bezel. It is cracked in 3 places so I would like to replace it? Also, if you have any advice, I am open to it.
Thanks in advance
CAH2873
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I would make sure the oil and temp gauges are the actual culprits and not the wiring or the sending units.
Jarhead79
Mt Vernon il
Michael
You might be able to use some 1000 or 2000 grit sandpaper then buff the lenses with a buffer to get rid of the haziness. I did this with a set of challenger headlight assemblies that someone had taken a scotch bright pad to. Sanded them and buffed them and they turned out perfect!
cah2873
East Texas
Chance
Any advice on how to check the gauges out? I have removed the whole cluster and the 2 gauges plug into panel which goes out to the wiring harness. is there a way to check them out of the panel?
richard
mi
richard
383 stroker
reinstall cluster find oil pressure switch remove wire turn key on if gauge pegs it is ok do the same with temp gauge
MikeD
