In search of th400 kickdown switch and such
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
My c10 has no electronic th400 kickdown, as it was originally a inline 6 truck with a 3 speed
Manual Downshifting and standing in it is fun and all , bit i'd like to just have the kickdown solenoid working
Anyone here have the switch and all for a th400?
I have the pigtail that goes to the trans, but nothing more.
Thanks.
Vbb199
Salisbury NC
Vince
Boop boop
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Thanks.
I may have one for a th350. If that'll be the same, I'll go look.
If it isn't, then I can't help you. Don't have any th400s
idahovette
Weiser Idaho
Perry
K20-K10
Do you want the one under the dash on the pedal or the one under the hood, plunger style on the carb or throttle body?
Vbb199
Salisbury NC
Vince
I reckon under the gas pedal would be ideal, but i'll take whatever you have perry, name your price
Vbb199
Salisbury NC
Vince
The th350 uses a cable kickdown, a 400 uses an electronic kickdown
idahovette
Weiser Idaho
Perry
K20-K10
@Vbb199 I posted pics, but a caption says waiting for moderator approval.....What the hell is THAT??? @bucket , @animal ... HELP!!!!
Vbb199
Salisbury NC
Vince
Here you go.
@idahovette @Bextreme04 is this something you have to kinda adjust for your kickdown/shift point? I hope it is.... until i have fat tires and a locker, this switch will singlehandedly make drivability pretty violent.... when i was doing about 45, i manually downshifted to see what would happen, the tire broke loose, barked and spun HAHA
I am hoping i can set the throttle position that causes the kickdown
So it appears the little peg sticking out gets contacted by the pedal arm and then completes the circuit?
Vbb199
Salisbury NC
Vince
@Vbb199 pics, this mounts at the carb or whatever you got feeding that BBC.See it works!
I have holley efi up top feeding the big block, wondering if i could maybe rig it to work on the throttle linkage?
Is that for sale?
It's not really adjustable. It auto adjusts with a little ratchet thingy inside it. You flick it and it releases and comes all the way out. Then you put the pedal all the way to the floor and it ratchets in and adjusts to a certain percentage of full throttle.
83elcowes
