Ignition switch r&r
aGood'olBoy
Waterford Pennsylvania
Jeremiah
Well I need to replace my ignition lock cylinder and other than pulling the steering wheel I don't have too much of a clue what I'm doing. So if anybody could help me out a little and tell me what all is involved that'd be appreciated. As always any and all input is appreciated.
aGood'olBoy
Jeremiah
I forgot to mention I also need to replace my turn signal return springs while I'm in the column.
aGood'olBoy
Jeremiah
I really should get an account on that forum they have a lot of great write ups. Anyways thanks I appreciate that.
MadOgre
NA
NA
NA
NA
NA
I keep that one on my favorites. I have to do that one of these days. Not looking forward to it though. Hope it goes well for you.
hinkv10
ct
craig
v10
look under suspension steering and brakes in this forum. Its a sticky and gives step by step instructions on taking apart the column all the way to the bolts that loosen up. After doing that replacing a lock cylinder is a walk in the park.
Here is another option - check with your local junkyards.
Most of them will sell you a complete column from the steering wheel down to the flexible coupling (rag joint) for a very reasonable price. I don't think I have ever paid more than $75 and that one was a tilt column with a tight lock cylinder (and matching keys).
