i6 to 350 swap need help
jairie laplante
canada
jairie
i have a 1981 with the 250 i6 and i want to swap to a 350. i have been able to find that the motor mounts work the same but cant seem to find if my transmission will just bolt up to the 350. i have the 3 speed manual Saginaw transmission and want to keep it. so my question is what will i need to do to make the engine work with that transmission.
crpntr78
Missouri
It will bolt right up. Did it on my 84.
jjester6000
Illinois
Jack
C1500
Yea, you literially need nothing extra to get it to bolt it up. If you are using an engine from '86 or later, though, you will need a different flywheel since they use a different crank flange.
jairie laplante
canada
jairie
thanks
86sunnyguy
