I need help! the steer shaft is gone... I think
raylanr
Campeche, MEX
Franc
Okay I need all the input I can get to get my baby fix... check the pic...
Got your back here, Changed title from drive shaft to Steer Shaft !!! HRPC
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
This isn't a drive shaft.
8T6K5
AZ
L98 350 TPI
That was a lot of help....
Correct that is not your drive shaft. That is your steering shaft, rag joint and steering gear box.
Okay I need all the input I can get to get.......
Now what is the problem? Your gonna need to provide more input than just a pic.....
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
What did you expect me to say..lol
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
If you think that is a driveshaft take it to a mechanic.....better?
raylanr
Campeche, MEX
Franc
I knew I was wrong, and I take the advice with the sarcasm too.
It wont turn, the joint plate is broken and the ring around it... I was backing up of a parking space and when I tried to turn left to take off, I heard the snap and now is sitting there... on the curb... while I do the research and get what I need to fix it, and get back to work.
thanks.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Argh, unfortunately you'd also have to change the steering column if it hasn't been done. :(
You can get replacement rag joints at most auto parts store. But they just go bad again in a short time.
RetroC10Sport
Jay
pontiac aztek
I did see that Wrench-A-Part got in some 1978-83 trucks if you want to go ahead and do the mod. If you need help, I am available most of the weekend, Pflugerville isn't that far from me.
I also have a couple of already modded shafts.
raylanr
Campeche, MEX
Franc
I need this thing going, not sitting there, I think I'm going to get the rag joints and replace those and get it going...
what else you think I should get?
RetroC10Sport
Jay
pontiac aztek
I think you're okay with a replacement rag joint. It should come with the brackets that bolt to the shaft and splined part. But it appears to be about $50. It's a steering coupler when you go to the parts store.
raylanr
Campeche, MEX
Franc
I could really use the help, I like to do as much repairs as I can, I have a friend that has a 16 year old boy that wants to learn to so he wants to come help and learn... would sell me one of those shafts?
RetroC10Sport
Jay
pontiac aztek
You bet. I have dr's appts today and tomorrow. You would just need to update the steering column ($45 at Wrench A Part - might be $34 if I go and Angie is the cashier!) and I'll just give you one of the modded shafts, I have so little in it and would like to help a squarebody owner. :waytogo:
GRat
