I checked my fuel pressure - help me understand my readings
Mattchu60
Iowa
Hello All, I checked my fuel pressure tonight. Here are my results:
Key On - comes up to around 10-12 psi, then falls back to 0 slowly.
Key On, Engine Running - comes up to 12 psi and stays there.
Readings were taken from the location of the fuel filter.
I think these are acceptable since it falls within the 9-13 psi range? What worries me is that with key on, engine off - the readings fall back to 0 after a moment, shouldn't the pump be pushing?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
The pump will prime for a bit, and then turn off until you start the engine.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Yes, TBI does not hold pressure. Is this an inline fitting at the filter?
Mattchu60
Iowa
Yes, this is an inline fitting which is directly in front of the filter in line.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
The adapter is supposed to go behind the filter, on the tank side.
Mattchu60
Iowa
Do you mean behind the filter - as in behind when facing from the front of the truck?
Currently the adapter is on the rear end side of the filter.
In the flow of fuel, it is in front of the filter in the line, as the flow of fuel comes from the tank forward. I want to make sure we are on the same page.
RetroC10Sport
Jay
pontiac aztek
attachment.php
chengny
To check system leak down rates you need to somehow temporarily restrict the flow through the return line. The shop manual uses the term "briefly" which is misleading - they mean the entire time the leak down is being checked. See the table at the bottom; your 12 lbs is well within range. But unless you block the return line you will not get an acceptable pressure retention time.
The most critical and truest evaluation of the system is the fuel flow rate. They don't come right out and say it but if you get your beer can full of gas in 15 seconds (or less) you can stop testing the fuel system - you are good.
FUEL PUMP FLOW TEST
1.Disconnect the EFI fuel feed line, then connect suitable hose to line and direct end into suitable container.
2.Apply battery voltage to the fuel pump test terminal. The fuel pump should supply 1/2 pint or more fuel within 15 seconds.
3.If fuel flow is below minimum, check for fuel restrictions. If there is no restrictions, check pump vacuum and/or pressure.
FUEL PRESSURE TEST
- Turn engine "OFF" and perform Fuel Pressure Relief procedure.
CAUTION: A small amount of fuel may be released, after the fuel line is disconnected. In order to reduce the chance of personal injury, cover the fitting to be disconnected with a shop cloth. Place the cloth in an approved container when disconnect is completed.
- Install fuel pressure gage J-29658A/BT8205, or equivalent, at the outlet side of the in-line fuel filter.
- Start engine and observe fuel pressure reading. It should be 62-90 kPa (9-13 psi).
- Relieve fuel pressure.
- Remove fuel pressure gage.
- Re-install fuel hose or pipe assembly to in-line fuel filter.
- Start engine and check for fuel leaks.
*** THIS PROCEDURE HAS BEEN UPDATED BY TSB # 90-6C-89, Dated 9/90
Some 1985-90 engines equipped with 2.5L, 2.8L, 4.3L, 5.0L, 5.7L or 7.4L may experience a condition where fuel delivery is interrupted to the engine causing a "no start condition". This condition may be caused by deterioration of the in-tank fuel pump coupler hose located between the fuel pump sending unit and the fuel pump. This condition may be repaired by replacing the original coupler hose with a new VITON coupler hose kit P/N 25028041. The kit consist of a new VITON hose and two clamps.
Pressure, Vacuum and Temperature Specifications:
Mattchu60
Iowa
RetroC10Sport - that is exactly how I have it installed. I think we are saying the same thing in different ways.
:popcorn:
boarder421
