Whit52
- Jul 28, 2025
- Marysville
- Kerry
- V20 Suburban
1987 V20 Suburban. Replaced leaking heater core. Then discovered, after installation of heater distributor box, that hvac air distribution is all wrong. Heat comes out of a/c vents. A/C and defrost comes out of lower heat vents. No air out out of defrost vents. Did I misplace vacuum hoses on the two actuators? One vacuum hose goes on defrost actuator at driver's end of distribution box. Hard to misplace that hose as it is far away from the AC/Heat actuator located at back, middle of box. This actuator has 2 ports. I placed blue/black hose on port closest to driver, and a brown/black hose on the other port. Also, reinstalled metal cable on top of box. What have I done wrong?
