How to use a jack...
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
...and now you know
Good thing the “artist” knew what the rear axle looked like, or not.
Moderator
...and now you know
I've never seen that set of instructions before. Civilian trucks had the jacks stowed under the hood.
climb-101
montana
seth
c2 crew cab
6.0 LS
here is what’s on my ‘74 2wd. jack and instructions
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Is your actual rear axle u-bolts over or under?
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
yeah ive got 4 of those, I use em as jack stands too. worth snagging them at the junkyard.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Instructions??? Who needs instructions??? I find the trial and error method much more interesting! LOL:cheers:
climb-101
montana
seth
c2 crew cab
6.0 LS
mine are from the top down. they have some stamped steel plates that go on top of the leaf springs that hold the u-bolt in place and cast steel piece thatfits over the axle tube that the u-bolts go through then the nuts go on from the bottom
JMSYE
