How to Remove Gauges 1987 Silverado
bcbbabtexas
Tomball
Baron
r10
Ok, once again I am back. Thanks for all the previous help. The previous owner has left a lot of wires that go nowhere behind the dash. I have taken off the bezel, clear cover and black cover behind it. How do you get the white/green colored plastic piece that holds the gauges OUT? I have the screws out but dont want to force it. Also, does anyone know where the wires from the Dual tank selector switch go?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
You didn't need to remove all that. Reach up behind the cluster and find the speedo cable, you will need to unhook it first. There's a tab holding it to back of the speedometer that you have to push while pulling on the cable. You can then gently slide it to the left and up, it will go just might take a little force but not enough to break anything.
Milblazer
Colorado
MilBlazer
When you say the wire for the tank selector switch what do you mean? The wires at the fuseblock, the tanks, the switch, or into the engine bay?
bcbbabtexas
Tomball
Baron
r10
tank selector
I had a previous post where I wasn't getting fuel, realized the passenger tank was empty and the tank selector switch was broken and not even wired. I bought a new switch and some used wires with the plug but need to find out how to wire it since it's not there.
Kipps5000
