How to get 2 inch drop on 91 r1500
Dtrain
New Jersey
Dennis
Suburban R1500
350 cu in
hi All
What kit do I buy to get a 2 inch drop on my 91 gmc r1500 suburban?
Thanks
Dennis
varmit86
Washington
Mark
C30
I would look for spindles up front and the shackle and hanger in the rear that should give 2 in front and 4 in the rear to level it out. might have to C notch the frame also or just do the shackle and that will give you 2 inches and should not hit.
there are alot of ways some cheaper but this is problem free.
Dtrain
New Jersey
Dennis
Suburban R1500
350 cu in
Thanks for your help, I’m not sure how to c notch the frame, can I just use the shackles and 2 “ spindles in front without notching?
TravisB
Kentucky
Travis
Some say you can get away with a flip kit without notching. It would all depend on whether your axle hits the bump stop after you lower it and how much that bothers you. I notched my frame in my build thread with a cut off wheel and a sawzall. I didn't really make a guide there on how to do it but youtube has a ton of videos on it. Some notch kits if you go that route will have instructions and guides as well.
FenderBanger
