Hood liner: Asbestos?
Loww
Germany
Dominic
GMC K20
Hi,
can anyone tell me, whether this two parted hood liner in my 1979 GMC K25 (Californian Truck, Fremont Plant) is the factory installed original part? If yes, what are the chances, that it contains asbestos?
Thanks!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Probably a good chance it has asbestos in it lol I’m not sure though. I believe that is factory
Thefaceless023
Bilkings, MT
Martin
doubtful EPA clean air act of 1973 outlawed asbestos use for insulation and fire proofing, its likely GM quit using it then too. Even though the total ban didn't happen until 89.
It’s interesting to me that this was brought up because I had wondered the same thing myself, but I wrote it off as a probably not. Are there any other carcinogenic substances we come into contact with, particularly relating to fluids, new or used, brake parts, or solvents that anyone can think of?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Reminded me of this. .lol
I’d read about the motor oil. Yuck. I’ll start wearing gloves from now on.
Big Chip
Michigan
Kevin
C35
I’d be willing to bet California banned the use of asbestos before the feds mandatated it.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Even here, asbestos was used in home materials into the 80s.
To the op. You’ll be okay. You have to disturb quite a bit of asbestos fibers to damage your lungs. It’s probably all over your house if it’s pre 1980.
The bulk of my work for property management companies involves environmental remediation, though usually mold related to leaks. There are labs you can send a sample to if it’s keeping you up at night. The test is under $40.
Snoots
Roger
Jimmy Sierra
350 w/203
Asbestos was used in some underhood applications until 1989.
The only way to be certain is to, like Frankenchevy said, have it tested at a lab.
chubhub6969
